Go Back   ModularFords.com > Modular > 2005 - 2010 Mustang GT
Reply
Old 11-06-2009, 12:07 AM   #1
ridir frith
Status: Junior Member
Default Gas smell, searched but located nothing
I searched the forum and found nothing. My 06 GT has a strong gas smell inside when running. Anything to check, is this a common problem or am I blessed with the only one?
ridir frith is offline   Reply With Quote
Old 11-06-2009, 12:15 AM   #2
FireFighterHill
FireFighterHill's Avatar
Status: Moderator
Send a message via AIM to FireFighterHill Send a message via MSN to FireFighterHill Send a message via Yahoo to FireFighterHill
An 06 Mustang GT? Have you done any mods at all?
__________________
2006 Tungsten Mustang GT 5-speed
Engine: Shaker hood scoop, C&L CAI, 93 Octane Tune, Steeda UDP, Meizere electric waterpump, CMDP's, Optima Red Top battery
Transmisson: Steeda Tri-ax
DriveTrain: Spyder Aluminum Drive Shaft
Exhaust: Flowmaster Mufflers
Supension: Tokico D-specs,Eibach prokit springs,Eibach swaybar kit,BMR adj. panhardbar,BMR panhard brace, BMR boxed LCA's. BMR Adj. UCA and mount.
FireFighterHill is online now   Reply With Quote
Old 11-07-2009, 11:51 PM   #3
ridir frith
other than a non functional hood scoop, nothing has been done. Have cai and tuner but gonna fix the gas smell first
Old 11-08-2009, 12:44 AM   #4
Bullitt1992
Status: Senior Member
Are you running a canned tuned via your tuner currently, or stock tune?
__________________
2001 Mustang Bullitt #01992
BBK X-Pipe, Dynomax Cat-Back, Tri-ax, JMS SCT Tune, 3.73's, Koni SA's, H&R Super Race Springs, Spec Stage 2, Mach 1 Grille Delete, Mach 1 Chin Spoiler
Bullitt1992 is offline   Reply With Quote
Old 11-08-2009, 06:33 PM   #5
hypersurf1
hypersurf1's Avatar
Status: Member
The fuel pump is under the rear seat, make sure its sealing well and not leaking. Just pop the levers under the seat and lift it out.
__________________
2007 Shelby GT
Performance white
Paxton Supercharged
499rwhp 440rwtq
4.10's
hypersurf1 is offline   Reply With Quote
Old 11-09-2009, 05:25 PM   #6
Vapour Trails
Vapour Trails's Avatar
Quote:
Yes, make sure the lock ring is sealing properly.
I had a fuel pump replaced by Ford under warrantly and the retards didn't secure the lock ring under all the tabs, and fuel leaked out at a steady pace.
Vapour Trails is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
American Racing Headers Blow-By Racing BMR Fabrication Campbell Automotive D'Agostino Racing Diablosport Dynojet Research Edelbrock Evolution Performance Forced Air Performance Fore Precision Works Granatelli Motorsports Holcomb Motorsports HP Tuners J&M / Hot Part Kenne Bell Lethal Performance Lightning Force Performance Livernois Motorsports M&H Tires Metco Motorsports Ninosport Mustang Parts Powerhouse Racing and Performance PSI Motorsports Saleen Techco
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Brooks Speed Inc. / ModularFords.com © 2002 - 2009
