Go Back   ModularFords.com > Modular > 1999 - 2004 SVT Lightning
Reply
Old 11-05-2009, 09:11 AM   #1
dilligaf
Status: Junior Member
Default Rear shackle trade
I have 2'' lowering shackles on a 2004 I just bought. It only has 32k and the shackles look like were recently installed.
Does anybody want to trade for a pair of factory ones? I do a fair amount of hauling, and it just makes more sense to me to have the factory ride height.
dilligaf is offline   Reply With Quote
Old 11-05-2009, 10:04 AM   #2
fishin-nole
Status: Member
They will not effect your hauling capacity. I pulled my wifes Jetta on a 18ft. trailer 350 miles up and down the hills of Ga. from Atlanta home to FL.
fishin-nole is offline   Reply With Quote
Old 11-05-2009, 10:51 AM   #3
kevmac
Status: Member
They do affect wheel travel and the truck bottoms out a lot more. I am curious if someone makes a shackle with stock height and a couple inches lower built in so you don't have to change out the whole deal when you want to tow something heavy. I had to trim my bump stops because it bottoms out on a launch at the track, towing 1000's of pounds definitely makes it worse.
Kev
kevmac is offline   Reply With Quote
Old 11-06-2009, 06:41 AM   #4
fishin-nole
Status: Member
You must be missing a leaf spring then. I have a 99 and mine does not bottom out with the 2" shackles. Lots of folks pull a leaf or 2 on the later year models when lowering them. Try some of the other sites classifieds, I see stock shackles from time to time.
Old 11-06-2009, 11:08 AM   #5
kevmac
Status: Member
I bought my 01 truck off a 74 year old man with 8000 miles on it and I have never removed any leafs. He had some belltech shackles on it and I installed long bars. I used to have troubles launching with the power turned up, it would bite, then bounce off the snubbers and unload the suspension causing it to shake the tires. I trimmed the bumpstops and that seems to have pretty much fixed it for the most part. I put a dab of grease on the axle tube to figure that out and you could see after a pass where it hit. I haven't tried that since I trimmed them, however. I wouldn't be surprised if some of the big power trucks nail them all the time. With some wieght in the bed it will touch them on a good speed bump. There's not a lot of travel back there when lowered and trailer takes even more away.
Kev
Reply
Bookmarks
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
American Racing Headers Blow-By Racing BMR Fabrication Campbell Automotive D'Agostino Racing Diablosport Dynojet Research Edelbrock Evolution Performance Forced Air Performance Fore Precision Works Granatelli Motorsports Holcomb Motorsports HP Tuners J&M / Hot Part Kenne Bell Lethal Performance Lightning Force Performance Livernois Motorsports M&H Tires Metco Motorsports Ninosport Mustang Parts Powerhouse Racing and Performance PSI Motorsports Saleen Techco
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Brooks Speed Inc. / ModularFords.com © 2002 - 2009
