Go Back   ModularFords.com > Buy and Sell > Vehicle Classifieds
Reply
Old 08-24-2009, 11:39 PM   #1
sukkoi19
sukkoi19's Avatar
Status: Member
Default 9 Second 1991 Renegade Style Coupe FS/FT
Up for sale is a 1991 Mustang Coupe that was for the most part modeled on NMRA Renegade style racing.
Chassis
~Rust free 1991 coupe original 4 cylinder
~10 point cage with window net done to 8.50 cert
~Dual Kirky Racing seats with black padding and in date 5 points
~New black carpet with full interior
Suspension
~UPR Mustang Pro-Series Extreme Rear Suspension Kit
~UPR K-Member
~UPR A-Arms
~UPR Front Coilover Kit
~Strange 10 way shocks front and rear
Short-Block
~Dart Iron Eagle 4 Bolt Block
~Callies Crank
~Carillo Rods
~Diamond Pistons -3cc
~Comp Link-Bar lifters
~Custom Bob Kurgan Renegade cam
~Has two dyno sessions and about 20 passes on it
~327 CI
Top-End
~TFS Twisted Wedge heads 2.05 Intake/1.64 exhaust otherwise stock
~Holley Systemax Intake unported
~75mm Throttle body
Exhaust
~Mac 1.75" primary automatic style longtubes with true 3" collector
~Custom 3" X-Pipe
~Dynomax race bullets and Magnaflow Race muffles both with ball flange for easy change
Power Adder
~Vortech Driver Side YSi with Renegade mounting plates
~3.00/8.00 8 rib serp setup approx 24# at 6400 RPM
~Snow Meth kit with custom dual nozzle and 1 gallon tank setup
~Has two dyno sessions on it
Fuel System
~Dual Aeromotive A1000 pumps
~-10 feed
~-8 Return
~Aeromotive High Bypass Regulator
~Cartech .5" polished aluminum fuel rails
~15 gallon cell
Transmission
~Full manual VB reverse pattern TH400
~Transmission Specialties 9" race convertor currently stalling about 5300 RPM with this setup
EMS
~SCT chip tuned by Bob Kurgan
~MafIA extender
~A9L
~SCT 2400 MAF built into charge pipe
Rolling Stock
~Billet Specialties
~15X3.5 Fronts
~15X10 with 6.5" BS rears
~Mickey Thompson front runners
~Mickey Thompson 10.5WX28 rears approx 5 passes
I am sure there are a hundred little things I am forgetting. The car went 9.51@142 mph last year with a hot air T-Trim setup and no front suspension. Since then I have added the meth, YSi, and the tubular K-member and A-arms and coil overs. The car should run a lazy 9.00@150 mph as is so far just in a shake down pass with no brake and no full throttle off the line it has done a 9.41@147 mph. I will give out dyno numbers only over the phone.
I would like to start at $17,000 OBO and would be interested possible trades for 03/04 Cobras or nicely modded 99-2002 F-Bodies.
309 781 4774 ask for Ben
Pass on old combo:
YouTube - Ben 9.63@139
Last years dyno sheet with hot air T-Trim through TH400
Trailor that will come with it for another $3000. 2001 Haulmark 20' little use.
sukkoi19 is offline   Reply With Quote
Old 08-25-2009, 01:29 AM   #2
Seraphim38
Seraphim38's Avatar
Status: Senior Member
bad ass car! good luck on the sale.
Seraphim38 is offline   Reply With Quote
Old 09-02-2009, 02:04 PM   #3
LS KILR
Status: Junior Member
wanna sell trailer out right
LS KILR is offline   Reply With Quote
Old 09-03-2009, 02:24 AM   #4
sukkoi19
sukkoi19's Avatar
Status: Member
Sure, but I would like to get around $3400 for just it if the car is out of the equation.
__________________
~1997 Crystal White Mustang Cobra
~1995 Rio Red Mustang GT
~1994 Rio Red Mustang Cobra
~1991 White Mustang Coupe...Shared Project
Old 09-08-2009, 12:41 AM   #5
sukkoi19
sukkoi19's Avatar
Status: Member
Updated times and vid:
http://videos.streetfire.net/video/B...ang_706205.htm
Car went 9.21@148 with a 1.300.
__________________
Old 09-14-2009, 03:36 PM   #6
sukkoi19
sukkoi19's Avatar
Status: Member
Bump.
__________________
Old 09-16-2009, 09:55 PM   #7
flyin_hawaiin
gotta love that stock computer stuff LOL
__________________
Bob Kurgan
8.06 @ 172.5.. doing it with BFG's!!
7.88 @ 175.8.. doing it on MT DR's!!
2000 NMRA EFI Renegade World Champ
2000 NMRA Renegade Orlando Champ
2001 WFC Renegade Champ
2005 NMRA Renegade Bradenton and KC Champ
2005 NMRARenegade RT 66 R/U
2006 NMRA Drag Radial Reynolds and BG Champ
2007 NMRA XS BG & NMRA Drag Radial BG R/U's
2008 NMRA Drag Radial FL and GA R/U
2008 NMCA FL XS Champ
flyin_hawaiin is offline   Reply With Quote
Old 09-17-2009, 06:22 PM   #8
sukkoi19
sukkoi19's Avatar
Status: Member
It would be nice to get an 8 with it. I guess we will see with the cooler weather if its possible. Not like its going to sell anyway.
__________________
Reply
Bookmarks
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
