Go Back   ModularFords.com > Modular > 2003 - 2004 Mustang Cobra > Turbo Terminators
Turbo Terminators Technical discussion of Turbo-Powered 2003-2004 Mustang Cobra "Turbo Terminators"
Reply
Old 10-03-2009, 05:37 PM   #1
2bscrewed
Status: Senior Member
Default Working out the bugs
Well, I went to Richmond for street night last night to see what the new intake would do. Everything is the same from the last time I went to VMP and could only muster a 12.2@ 128 (car only dyno'd 620hp). 17.5#'s, pump gas, and 13* timing, 17" M+H DR's and 4.10 gears. This time, still with no 2 step, the car was still a pig off the line. I also think Ed may have dropped my rev limiter down to 7k rpm accidentally, because any time I waited to see my shift light at 6900 rpm, it would hit the limiter and cut out for a second. The last pass I revved the car a few times right before launch and it helped tremendously, but 1st gear went by real quick, so I hit the limiter again. So once I put the 2 step on, I will probably drop down from the 4.1 gear to a 3.73, and see how the turbos like that. My clutch was also acting up on the way to the track, but seemed alright once I got there, it may be slipping a bit up top though, cause the MPH still seems a bit soft. The car dyno'd 698 hp last time I was on it.
http://videos.streetfire.net/video/2...ith_710653.htm
__________________
Black 03 KB Cobra Best of 10.65@ 132 1.57 60' on pump and DR's
Working out the bugs on a Hellion TT and built motor now!
Best of 10.53@ 131.5 1.56 60' 17#'s, 14* 17" DR's
http://videos.streetfire.net/video/N...053_723784.htm
2bscrewed is offline   Reply With Quote
Old 10-06-2009, 09:50 PM   #2
2bscrewed
Here is another pass from Friday. It was horrible off the line, but you can hear how quiet the car is even though it has a full 3" off road exhaust with 3" straight through Magnaflow mufflers.
http://videos.streetfire.net/video/Q...ass_711397.htm
__________________
Old 10-07-2009, 08:15 PM   #3
2bscrewed
Here is an in car video on the street.
http://videos.streetfire.net/video/I...the_711604.htm
__________________
Old 10-07-2009, 11:04 PM   #4
y2k2gt
y2k2gt's Avatar
Your car would be alot quicker with 3.27 gears! The 4.10's are just killing it.
__________________
2002 Mustang GT
Twin 60mm Turbos..Ported PI Heads...
Turbo Cams..Edelbrock Intake..Return Fuel System
C4 transmission..Spooled 8.8.. 10-Point Cage
643/588@18psi
y2k2gt is online now   Reply With Quote
Old 10-08-2009, 08:04 AM   #5
2bscrewed
Quote:
I'm gonna drop to a 3.73 this weekend. If I go any lower I won't ever be able to use my 6th gear. With the Viper spec OD and the 28" tires I don't even hit 2k rpms til almost 80 mph as it is with the 4.10's. Once I get everything worked out with the car, I will probably put an aut in it if I can find one with OD that will hold up.
__________________
Old 10-08-2009, 03:43 PM   #6
y2k2gt
y2k2gt's Avatar
So, don't use the 6th gear!
__________________
2002 Mustang GT
643/588@18psi
Old 10-08-2009, 03:57 PM   #7
2bscrewed
Haha, it's a street car first. Honestly, if i had a 2 step on last friday and would have pulled a 1.7 or 1.8 60' i probably would have been decently in the 10's, so the 4.10's can't be hurting that bad. I only dyno'd 698hp and the car weighs 3700#'s with me in it. Not bad for pump gas, DR's and full weight.
Does anyone have any vids of their stick turbo cars on 3.27's at the track?
__________________
Old 10-08-2009, 06:03 PM   #8
y2k2gt
y2k2gt's Avatar
When my car made 538rwhp with the 5 speed it ran 11.20's @ 126 with 3.27 gears and 26" tire.
When it made 540rwhp with the C4 it ran 10.5x's-10.7x's at 130-134mph with 3.27 gears and 28" tire.
__________________
2002 Mustang GT
643/588@18psi
Reply
Bookmarks
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
